Are you going to have 4 WD with the E4OD? If you are have fun. Lot's of work. Engine mounts, tranny mount, transfer case if separate from tranny, if not new tail shaft on tranny, drive shafts, Vss on rear diff., tone ring in rear, complete wiring harness from PSD, Throttle peddle with TPS and IVS, don't know about the radiator, if turbo should be, exhaust change Y and up & down pipes, steering post/wheel with shifter, GP controller WTS, transfer case manual or electronic?, under hood fuse and relay box, and prolly other things I can't think of. Sell the 86 and restore the 96.
Definately not selling the 86 and the 96 is a piece of ****. I am planning on using the 4speed behind the powerstroke. The E40D is 2x4,messed up(hence my first post.) Will be deleting the e40d and using the t19 with the BW manual transfer case. I already have the 3" Downpipe on the engine that will hook straight up to my dual 3" exhuast if i cut the driver side off the Y. All stock drive shafts will work and stay in place.
