95 f350 mini leaf pack lift qurstion
Kraig
Louisiana
Hey guys,
Has anyone put the mini leaf packs on their OBS f350? I have the u bolts, packs and spring center bolts but am wondering what else I need for the install. This is my daily driver so I need to have everythibg ready to put it all on at once.
I am thinking I may need a track at drop bracket (such as the skyjacker TB35), and a drop pitman arm. I am only leveling so I will be putting 3” worth of mini leaves in the front. Please let me know what I will end up needing.
michael wolk
Paragould, Ar
No clue on mini leaf bud but i can tell you that skyjacker makes lift kits that work with the obs 7.3s 4wd and 2wd srw and drw
James Case
Long Beach MS
I’m currently installing 3” leaf packs on my 350 as we speak. When I unbolted everything the axle shifted to the driver side. Having trouble pulling it back straight to line up the center pins on the spring perch. Wondering if I’m gunna have to remove sway bar links or unbolt the leaf springs from the shackle.
