94.5 zf5 grinding into 2nd..
Travis91
Hartford/Dothan,AL
my trans is grinding going into second if i shift to fast.. i dont know the history of this truck and i want to change the tranny fluid today.. Ive been told to use lucas semi syn(3qts) and a qt of lucas oil stabliizer. filled from the top with the stick taken out. is this common practice? and 75w140 in the rear diff..
dieseldirt
Vermont
Alot of guys including myself are running the Mobil 1 Synthetic ATF. Might as well change the Transfer Case fluid too, while you're at it.
I would recommend filling through the fill plug which is found on the drivers side of the tranny. That way you can avoid over-filling.
I use a hand pump that screws right onto the jug and sends the fluid through a little hose. Got it from Amazon. Best $5 I ever spent.
ZF5 (w/o PTO) will take 3.5 Quarts and T-case (w/o PTO) will take 2 Quarts.
Travis91
Hartford/Dothan,AL
No transfer case on a 2wd.. I changed it 3 quarts of lucas semi syn ATF and a quart of lucas oil stabilizer filled thru the shifter hole... Shifts perfect now.
War Wagon
Terry, MT
Mine had a grind going 2nd to 3rd. I changed the fluid with Amsoil syn ATF and my grind went away. I'm a believer in synthetics in the gear boxes. Worth the extra coin to me and defiantly made a difference.
Cv axle
