'92 F350 rear springs advise
TygreII
Rapid City, SD
OK, I have a '92 F350 with the regular axle in back. The springs on both sides have cracked and/or missing leaves. I need to replace them.
I would like to use this truck to haul a 12k 5th wheel. I believe it can with no problem after the spring problem is fixed.
FYI: I have a banks turbo and the 5 speed manual trans in it.
Which springs should I consider putting on my beast?
OlKoot
Creston Canada
I got my OEM rear springs from General Spring. Affordable replacements. If they can get the right ones for my 1970 Highboy, they can for you
u2slow
bilge rat
Coastal BC
99+ cab & chassis springs might be a good strong upgrade. They're 3" wide also.
ntjapkes
