90 GM 6.2 Help
grizzrider
bc
My 90 GM Van with a 6.2 is in Sacramento CA and stuck!
It ran fine all the way down there, shut it off but when it's started it goes to the high speed governor and stays there until the key is shut off.
It seems like the fuel pump is stuck in full fuel. The throttle linkage is ok, externally everything works fine.
I'd like some help, if it's an easy fix I might attempt it myself.
Any recommendations for a good shop in Sacramento?
Thanks in advance.
Alleycat
