Been hitting the truck pretty hard as of late. Not a lot of picture worthy stuff, but tons of misc. odds and ends getting finished up.
Heater hoses & coolant valve done
Coolant tank heater installed
Auxiliary fuse box installed
US gear wiring done & works!!
Head light sockets rewired for 9007 bulbs
turn signal lights rewired to 92-97 harnesses
Belts installed on engine
Pyrometer, Water temp & boost plumbing routed to cab
Temp sensor for Jeep cherokee oeverhead console installed
Throttle cable and Cruise cables are now installed
Transfercase shift lever figured out & tested - needs new bushings and painted. This was big since I've got a t-19 with a NP205 transfer case and a US gear overdrive. So I've got 3 things together that never were before. I used the 89 shift lever with a modified US gear shift arm. Bascially two pieces of flat iron with all thread between them to adjust the length. It's a little loose now, but with some new bushings it should be just fine.
I need to bleed the brakes, install the new clutch line and radiator then I should be able to take it for a victory lap around the yard. The engine compartment is about done.
This is the extra fuse panel I installed. It's not as water proof as I would like but should be fine. I put dielectric grease in all the connections.
This is the passenger side wiring. It looks neater in person. I've tried to not make it a total rats nest.
Looking at probably doing a set of aluminum shift nobs from bronco graveyard. I'll paint them though.
This is the coolant tank heater. It's mounted to the passenger side frame rail in front of the crossmember. One hose goes to the block and one goes to the heater hose going to the water pump. Pictures rotated 90 degrees not sure why.
