87 F-350 6.9 Turbo Diesel Club Cab 5speed For Sale
Steel piston
Victoria
Selling my Dream. $10,000 canadian obo
-6.9 Diesel -New OEM Lift pump -Remanufactured Stanadyne Injection Pump -Denso 4000 watt Starter -New OEM Glow plugs -ATS Turbo 088 -3 Inch Exhaust From Turbo 'Y' -K&N Air Filter -Radiant Fuel Heater Pre Heater Core -ZF5 Transmission -New Flywheel, clutch, pressure plate, Through out bearing, Fork, Master cylinder, Slave cylinder, Upgraded to Stainless steel hard Clutch line -Borg Warner 1356 Transfer Case -4x4 -Manuel Hubs -Bilstein 4600 Shocks -Michelin 235/85/16 Mud and Snow -12,000 lbs Warren Winch -Truck was Under Coated in 1990 -All tires sit on 16 plate 1 Ton steel Rims -Floor and under Hood has Hush-Mat installed - switches in cab for lights front and rear and winch. -CDR delete (no more sucking oil in from the valve covers)
m2rtin
