gem6.9
hello, i just instaled the c6 after i went through it and put a rebuild kit, new servo, valve body, pump,torque converter, modulator came with the kit and had pinkish looking color stripe on it . and when i go from park to reverse it works fine but when i shift to drive i have nothing unless i rev it way up and it like kicks in hard and goes away as you let off the peddle, is this a possible bad new converter or does it sound like some thing else any clues on what to check before i pull it back out would sure be apreciated.
