85 Ford rear break hard line, No longer made?
Cope
S.L.T.-C.A.
I tore the drivers side rear hard line off and now it appears that because the line has a NPT fitting on one side and a flare on the other it is no longer made?
I went to both the local Kragen and Napa with no luck.
I can't believe that a break line for an 85 ford is that hard to find?
Anyone ever change one of these and if so where did you get it?
Thanks again.
Danoflapper
Zeeland, Michigan
You can buy the correct diameter line, a flaring tool, and the appropriate fittings and replicate any of the hard lines on these trucks if you can't find the pre-bent ones.
Optikalillushun
Coal Region, Pa
same here, i cut the end off and relfared with the right one. autozone had it, only went there because my friend works there and can find almost anything just by looking at it with those odd ball items. if i can find the package ill let ya know what size.
but i digress, i bought a complete stainless steel brake line kit for my 93 f150 from npd and next time i need to do a brake line ill go that route and do em all for my 88.
