IHdieselfan
I've been work on my friends 85 with a c6 we put the motor back in. he drove approx. 200 miles trans good a first a little soft shifting but nothing that couldn't be fixed with a little vrv adjust. now it went to very soft shift and slipping nothing i did to the vacuum made a difference. brought the the truck to the shop. dumped some seafoam trans tune in there and run it and then dropped the pan found orange rtv a bolt out of the valve body and some nasty fluid and trash in the filter. drained the TC installed new filter filled with John deere HYGARD. now forward works like it did before but reverse is slipping when you give it some throttle. I adjusted the intermediate band. and played with the vacuum and no change. tapped a gauge in to the pressure port in front of the shifter. at idle in park i had 50 psi. in forward 60 psi. in reverse 80 psi. all those pressures seem low to me. is there a way to adjust trans pressure. I have rebuilt allisons and john deere 15 speed powershifts. I'm guessing that a c6 is about the same.
