'84 F250 4X4 front axle?
allczns
hi all, anyone know what front axle is under an '84 F250 (standard cab) ?
TTB or solid? It's a 6.9 auto if that helps.
thanks,
allczns
thanks!
...might go take a look at it, not too far from me, body looks good in the pics. It's an early 6.9 but if it has gone this far it should be OK.
cheers,
04_6.0
Lake charles
Yeah it is going to be the TTB front axle. The 44hd does it use 1 ton lock out hubs, hubs, rotors, and spindle? I thought it was the Dana 50 that did?
memphisrain
Calumet, MI
The HD44 used regular Dana 44 lockouts, but has a spindle with 8 bolts instead of 6, and 8 lug rotors. I believe the bearings are the same. Also, it has a D50 upper ball joint, but D44 lower, if I'm not mistaken.
mR
