7.3/T-19/Flywheel
Diesile
Smalltown, Ma.
Do to conversations with other folks including South Bend and the tech article, I was under the impression that the 6.9 flywheel, while not ideal would fit the 7.3.
The '94 7.3 turbo that is going in my '86 T-19 equipped ride disproved that.
Is there a flywheel that will work with the separate bell housing equipped T-19
and at a later date, with the ZF-5?
And using the same clutch with different discs?
typ4
Newberg,OR
why wont it fit, there is a spacer on some of the auto cranks that needs to be removed.
85hauler
Reno
I ran a 6.9 flywheel on a 7.3 in my '85 for nearly 100k before I sold the truck. The only thing that will keep it from fitting is the automatic spacer.
Diesile
Smalltown, Ma.
Whoa! Spacer? O boy, feeling a little amateur here. Looking right at it with a couple other
guys and still don't see the parting line........but that HAS to be it. Thanks all !
hesutton
The Anti-Anderson
Bowling Green, KY
It should just bolt right up. All IDI's use the same crank, 6.9 up to turbo 7.3 IDI. If it is an IDI flywheel, it should work.
You have a PM as well.;Sweet
Heath
85hauler
Reno
That parting line can "dissappear". I had to tap mine with a hammer before I could easily see it.
Diesile
Smalltown, Ma.
hesutton....Thanks for the PM reply. That is a great link and will keep it.
85hauler....I appreciate the lift in a low moment, man did I feel dilbert.
.......been a few moons since I crawled around the insides of a vehicle. A few years ago
it have occurred to me to look (and tap) for that line!!
