I have a 1993 7.3 turbo engine that I'm rebuilding. The block had to be bored .030 thou over stock to clean up the bore. I had the machine shop pressure test both banks after boring and found there to be a pin hole(s) in no 6 cylinder. The machinist then tells me he has a non turbo block he will sell me, or sleeve #6 on mine. He tells me that if his block tests good then it would be a much better block then mine sleeved, and proceeds to bore it out .030 thou to clean it up. The non turbo block pressure tests good after boring. I asked my machinist if the block will get pin holes after with dca in coolant, he says definitely not. My worries are that it will get cavitation after I rebuild the engine, since the pistons/rings wear on the bore, and that the cylinder bores could be very thin. Should I run this block or should I find a 6.9 to rebuild? How thick do these bores come new? Also are there 6.9 pistons with turbo sized pin hole? Thanks.
