To remove the precups there is a special tool but.... Nobody makes them any longer so... For me the easiest way to remove the cups is remove the injectors and make a brass rod. Round the end and just stick it in the injector bore then hammer the cups out. Now the hadr part... These cups have a designed installed height. They can be 2 1/2 thousands above or below the head. Thats all.... Don't think you can install them deeper or have them sticking out more than that. They will causea agsket leak if they are higher up that that.. A member had that issue some time back. Check them for corner cracks. You can use them with some crack but it can't cross the gasket fire ring...
