7.3 powerstroke obs part out / drive train
06cumminspower
browns summit, nc
I have a ford 4x4 OBS that appeared to be in a building that was burned up, and I will be selling a 4wd E4OD automatic 4 speed transmission, borg warner four wheel drive transfer case, 7.3 / t444e international Navistar v8 turbo diesel engine, and front and rear axle truck is f250 so It is not straight axle. I do not know the mileage or history of truck. (336)669-8790
*7.3 / t444e long block: complete with heads, front/rear cover, flywheel, front balancer. $650
*E4Od auto trans: with converter $375
*borg warner t case: $375
*front axle: spicer 50 $375
*rear axle: full float $375
*3" Down Pipe: replaces factory flat pipe and has bung for egt/pyro probe $65, 2 available and also have complete exhaust w/ banks monster muffler and will sell complete turbo-back exhaust with downpipe for $150
*4 factory aluminum 16"bullet hole wheels: fits all 8 lug pattern ford, dodge, chevy, gmc except 99-up superduty pickups finish is bad from burn but great to paint or resurface $125
*HPOP: high pressure oil pump $50
*starter: $50
*stock fuel pump: $25
*turbocharger: garrett gtp38 t4i $150
* I also have turbo pedestal and up-pipes
Dan6.9
Canada
Do you have enough parts for a turbo kit. Also would you ship it to Canada. Send me a PM if you can. Thanks
Extra cab reg cab what? Could be interested in exhaust, can u check shipping to 98844 please?
If you have an IDI this won't work for you just so you know.
eastsideauto
Denton, NC
He had that thing listed here in NC craigslist but I couldn't find it anymore. Pretty sure it's all gone.
Sent from my C771 using Tapatalk 2
RangerDanger
