7.3 idi max rpm governor screw
Daniel McCurdy
Evarts KY
Because rpm in a Diesel is controlled by fuel wouldn't removing the throttle limiting screw make the pump put out more fuel or will totally removing the screw cause something in the pump to mess up.
Wes made a thread a while back called "DB2 tuning guide" (I think that was the name). Give it a read and it should answer your questions.
Alleycat
