7.3 IDI core engine AND LOTS OF LOOSE ENGINE PARTS!
jhenegh
Truck Still Earns its Keep
Deerfield, WI
7.3 IDI for a rebuidable core. Many good parts like injection pump, lines, manifolds, heads, filer head etc. Engine is not locked up. I never saw it run but was told it had high oil consumption and smoke but ran when pulled.
$250 or offer on parts.
3I7 69I 4347
Many other 7.3 and 6.9 IDI ford diesel parts available, just starting to clean up some extras. Feel free to ask if I have something.
jhenegh
Deerfield, WI
95% complete engine above is still available. IP and lines are tentatively sold. Would rather sell complete but I can start unbolting.
Available parts that are from other 7.3 engines. Would love to sell big package deals! No reasonable offer refused, and I mean it.
  • One pair of 7.3 heads- look runnaable but unverified
  • One pair of 7.3 heads - also look runnable but unverified
  • One pair of 7.3 heads - hot tanked and disassembled - would probably need machine work to do it right
  • All the valves, precups, springs etc from the disassembled set of heads
  • 3X sets of 7.3 head bolts
  • Three driver side valve covers
  • One passenger side valve cover
  • One oil pump and pickup
  • Two Injection pump gears
  • One injection pump cover
  • One VAN oil cooler
  • One TRUCK oil cooler
  • Four driver side exhaust manifolds
  • Three passenger side exhaust manifolds
  • Two rear engine plates
  • One front engine plate
  • Four used fan clutches and one fan
  • ALMOST COMPLETE SERPENTINE setup. Missing the bolt-on idler pulley but I have NA Crank balancer w/ serp pulley, water pump pulley and a used WP, AC compressor, AC bracket w/ power steering pump & pulley, alternator and bracket, and the spring tensioner.
  • N/A air intake filter holder/bowl black metal round thing
  • IDIT stock aluminum air filter "turbo" holder/cover box
  • Two rough but usable positive battery cables
  • F-Superduty hydrobooster and MC with automatic brake pedal. OBS I believe.
  • Quite a few radiator hoses
  • A few IP feed lines
  • New vaccuum pump and a few used ones
That's about it! One big package and I will make you a killer deal. :Thumbs Up:peelout
ChevellRCR
Prosperity, SC
Would you be willing to ship the hydroboost setup? You say it's from an OBS truck? How much would you want shipped?
jhenegh
Deerfield, WI
As in the loose football shaped things on crossover pipes and NA Y pipes?
If so, no I don’t sorry Russ.
jhenegh
Deerfield, WI
Shoot me an offer on serp setup, I’m not looking for top dollar. Something fair.
Hydroboost is sold.
My self and the parts are in Wisconsin.
jhenegh
Deerfield, WI
Bump to the top. Looking for someone to take the whole lot. The engine is sold but most everything else is available. Its a whole tote full.
