7.3 IDI Bogging Issue
brandmid
Gastonia, NC
1989 F450 Super Duty 7.3 5 speed
It's my rollback that's giving me issues, I know it has no way of telling what gear I am in but I feel it more in 3rd gear it seems very sluggish and starts to kind of surge. This happens on both tanks but if its happening on the back tank and I switch it to the front tank it does fine then I switch back to rear and all is good for a little bit.
What could be causing this problem?
Greg5OH
MI
sounds like air intrusion, perhaps around the FSV?
brandmid
Gastonia, NC
I was thinking maybe air is getting in but if that were the case wouldn't I be experienced fuel leak down when I left the truck sitting a few days?
ifrythings
BC
When it does this, try removing the gas cap on the tank, if you get a hissing like air trying to get in then you may have found your issue, if this does happen the breather on top of the tank is plugged and will need cleaning.
Tim4
Md
Does the shrader valve on the filter head spit a bunch of fuel when you depress it at idle?
A fresh fuel filter is my first choice for your symptoms and then maybe a lift pump.
The surge would indicate air but filters and lift pumps are both cheap.
brandmid
Gastonia, NC
Actually when I re fueled yesterday I did get a hissing sound from the front tank
brandmid
Gastonia, NC
I'll check the fuel at idle today and get back to you
I'd recommend adding a fuel pressure gauge to your instrumentation. That would help take a lot of the guesswork out of this.
ntjapkes
