Mikey89014
The V10 case should be a 4R100. Top of the case will have two sensors TSS and OSS. No sensors it will be the 98 modular engine case (v8-V10)I would use it as a door stop. The parts are worth nothing for your build.
All 4R100 are PWM units. This feature can be removed with programming and pump mods.
ok cool, thanks a lot. I will use the diesel 4r100 then if both the truck PCM and trans are PWM. The V10 has no top sensors, it came from a 1997 or 98 V10 van
