just some things to button up like the crossover needs a nut on one side and a stud on one side that should take care of those leaks, bending the trans tube, get all the exhaust on hopefully and the air filter setup on. heard a faint whistle when i revved it up a little
need to unbolt it a little to get the intake hat on as i left it off to see if it would even fit at all. now one of the main things I'm concerned about is the fuel line heading up to the fuel filter from the IP is in the way of the filter tubing, can I cut a section out and replace it with fuel hose as to have flex to it and route it from the tube? also I have the cdr in there for now with the long tube, its supposed to be shorter i know as to connect to cover bracket. i don't really want to cut it so can I get a tube to fit it and the cover grommet? thanks again It's coming along well i think the worst part was the up pipe being stuck together. my friends always told me my exhaust didn't smell like other diesels, my 7.3 idi did smell differently if I remember but that was over 12 years ago. having the cdr not hooked up it kinda smells different but it could just be my imagination. P.S make sure you're oil sender and or feed line are on the block before you start it
I instantly shut it off
