mudduck
soon i will be starting a build on my old mudtruck , its going more in the truggy/trail truck direction rather than just mud .this is what it used to be
the truck is now stripped to bare frame, it was a gasser. im repowering it with a 86 6.9. i know theres really not a lot we can do with these motors on a small budget but here are my plans as of now.
1.moose pump
2.custom ground cam
3.either mister's or bb injectors
4.i would like to do some headwork , i thought i saw on here that you can run 7.3 heads on a 6.9 if you get the block drilled out for the larger 7.3 head bolts?i also thought i have seen something about usin powerstroke valves.
5. some type of aftermarket fuel pump , not sure which brand yet
6.twin turbos on custom made headers, and intercooled. im not doing twin turbos to make a huge amount of boost , more for quicker spooling and almost no exhaust to get in the way . it is a offroad only rig and will have hood stacks off the turbos.
7. remote mount oil cooler.
what i was wondering was is there any other differences between the 6.9 and 7.3 heads and if studded on the 7.3 heads how much boost could i safely push? also is there any reason why i shouldn't run a remote mount oil cooler on these motors? if there are any other things that could be added to my list that is somewhat on the cheap feel free to suggest it.
the rig will also be on 2.5 tons , one link suspension , a 2wd t19 trans runnin to a divorced 205 w/ pto for my winch and grooved 48 inch ags if it matters for the build of the motor.
1.moose pump
2.custom ground cam
