6.9/7.3 interchangeable parts?
cubinzkid
American Fork UT
Buying a running 6.9, just the motor. Plans are to rebuild it, but that's down the road. I have an '88 7.3, and I'm wondering what parts swap between motors? Injectors, lines, manifolds, etc. Anyone know?
Waystro
No Class
South Texas
What will swap over. IpInjectorsWater pumpIntakeExhaust manifoldsSerp set upAlternatorIp LinesValve CoversCrankCamRodsOil squirtersPiston?Oil pumpOil PanOil CoolerAll the bracketsI don't think the 7.3 heads will go on a 6.9 could be wrong Tho
lukewarmt
BCOilBurner
Canada
I believe the heads have different sized bolts and a different cooling passage. I THINK the heads can be swapped using special studs but I'm not sure. I believe the valves, rockers, can be switched however.
Almost everything. Lol
Obviously pistons are a different size.
Early press in squirters obviously won't work in place of bolt in one's and vise versus.
7.3 heads can go on 6.9 but visa versa requires enlarging bolt holes
Pistons dont swap over or rings
As far as I know every single other part swaps over both ways except press in oil squirters
jaluhn83
Upper Marlboro, MD
Only the earlier 6.9 used the press in oil jets, later ones are bolt in same as the 7.3. IIRC the break is around sn 179,000 (~Jan 85)
