6.9 & 7.3 IDI Commandment Lists - IDI Do’s and Don’ts
stick_witch
Homer, Alaska
So, I thought this could be a fun/informative thread for everyone, new and seasoned here on this forum, to view and to share their IDI experience.
The question is, what are your guys’ set of IDI commandments? Aka your do’s and don’ts?
Make them informative, make them funny, whatever you want! Leave em down below!:Thumbs Up
Detroit80
Wittmann, AZ
Don't....buy the stupid thing to begin with. God, I wish I would have just held out for a 460 truck...:frustrate
Actually, it hasn't been THAT bad since I figured out that I was a dumb-**** that should have just replaced the damn air filter, but it's still been an expensive pain in the back side to deal with, lol.
frankenwrench
overkill is under rated!
Weatherford tx
Don't take it to a shop that isn't known for dealing with these old beasts! Told my buddy I think he has a bad injector and instead of coming by my house(20 min drive) he took it to ford (1 hour drive) and the ****** there came out with a obd2 scanner and wasted half an hour looking for somewhere to plug it in on a 92 f350 idi. Claimed he was the head tech and he knew there was one on it somewhere or it wouldn't have run long enough to get it were it was. Then charged him 609 bucks to replace the one injector after claiming he found the obd2 and that's how he knew which one to replace with a bs Delphi injector and now it sounds even worse and took two days to "fix it". My buddy threatened to toss thermite at the truck till I educated him some on the truck and now he has a used set of bb code injectors and the thing sounds great! But ford knows best....
Scotty4
Do:
-Get quality gauges for best diagnostics
-monitor coolant and oil use
-attempt to allow cold advance to shut off prior to driving
-use scas/dcas
-use fuel additive
Don't:
-use suitcase crimps or wire nuts
-Ignore new noises and expect a shakey truck to not loosen a bolt or wear through a wire/hose
frankenwrench
Weatherford tx
Do:
-use scas/dcas
-use fuel additive
Don't:
I am not trying to argue the use of sca or dca, additives are very crucial and IMHO required. But what is the downfall of instead using elc? Again, not a topic of debate, but I do want the facts. If I'm doing something wrong I need to know
Clb
Another old truck
nannyfornia
Do realize why navistar developed the psd.
Do remember the recollections of guys turning 500k, my bud Sam for one.
Do use a meter on the timing.
DON'T be THAT guy!
Scotty4
I used ELC in mine and measure it woth test strips to help maintain everything appropriate using the ford scas. Maybe I am doing something wrong? Haha
miles1400
Macungie PA
do:
check the oil once a week
try to get the maintenance records from previous owner
use a ford FL-1995 oil filter
use fuel additives, especially anti gel stuff in winter
get up a little earlier in the winter so you can let the truck warm up on high idle before you leave for work or school
use the butterfly/wing/vent windows, your truck has them so use them, they are better than AC in my opinion
if your truck has a bench seat, use the seat on date night
always open the truck door for your date or girlfriend (if you are lucky enough to have a girlfriend)
don't:
use autozone parts, ever
use the tilt column, thats how you break ignitions
rely on the block heater to get the truck started, you cant plug the truck in when its in the middle of a parking lot
expect to impress your buddies with your dyno sheet
Detroit80
Wittmann, AZ
Sure...if you're a *********. Come down here to Phoenix in the middle of July when it's 115*F outside, and your truck has been baking in the sun for the past 8 hours...the thermometer inside the cab reads 145*...you'll dread just touching the door handle, or the steering wheel. Then go sit in bumper to bumper traffic on the blacktop, with your wing windows open...and tell me that it's still better than AC LOL
6T9burner
SVAZ
I'm dying reading this. I'm a bit south of Tucson. Summer time, going back and forth, it gets brutal if you have no A/C. First time I drove my old CJ7 (hard top and hard doors, at the time) from Cali to Tucson. I swear PHX was hotter than going through the dunes (summer time mind you). For some reason I kept hearing Christmas music in July... chestnuts roasting on an open fire...
miles1400
Macungie PA
detroit80, here in eastern PA we rarely see 100, it is in the 90s in the summer time but i still prefer butterfly windows over AC, even though my truck does have freezing cold ac
The_Josh_Bear
Western WA
Besides the wisdom above, I'll add--
Do:
  • Turbo, charge air cooling, max IP
  • 38 gallon fuel tank mod
  • Re-torque head bolts
  • Keep old iron on the road
  • Learn to wrench on your own rig, it's rewarding and fun.
  • Smile and wave at the Prius driver's that hate you. :rotflmao
Don't:
  • Roll coal (yeah I said it)
  • Take your rig to the stealership
  • Maintain over 1150°F on the pyro
  • Neglect your cowl seal! (If N/A. This can hydro-lock your engine. One more reason for a turbo!)
MadScientist
