PDPRacing
SCT Custom Tuner
- Joined
- Oct 13, 2005
- Posts
- 15
- Reaction score
- 0
As all we have to play with in our 6.0L's is what we got handed from the dealer lot, we have had to do our own R&D and I noticed ford had been trying to keep a clean running power plant for the 6.0L motor. I decided to do some experimentation, and found the "Banjo Bolts" ( the bolts that feed the fuel into each head ) to have quite a restrictor in the center, and only two small holes to dump the fuel into the heads. ( each head has 1 bolt )
I removed the Banjo Bolts and drilled larger the 2 stock holes, and added 2 extra holes, I also gutted the center restrictor.
Here is what your Banjo Bolts should look like after the Mod:
Banjo Bolt Pic1
Banjo Bolt Pic2
The stock fuel lines are metal and barely 1/4", I upgraded to 3/4" lines to compensate the fuel pressure with fuel volume, the both must go hand in hand. DJ's Performance Modded my Stock Fuel Pressure Regulator from the stock 40psi to a hefty 110psi. Now my injectors were liking this!
I decided last friday to take the truck to Test & Tune and run the Truck on my STOCK setting, with NO TUNER to see the results of the mods in conjuction with my injectors. I was very surprised, the 6.0L in the Fuel department has a hidden Monster. I did this because everyone on other sites are always asking me if these mods worked and how much HP/TQ it produced for me, and thought to take to a dyno, but decided you guys rather see some 1/4 times.
I'll let the Videos do the talking.
With those 1/4 mile Times, I was still posting 8.8, 8.7 1/8 mile runs.
Things that are small, but help in conjuction on the long run when matched with other things like a WELL Tuned SCT programmer!
-PDP-
Pure Diesel Performance
Banjo Bolt Pic1
Banjo Bolt Pic2
-PDP-
