5 ton military truck
chris88
Wayne, New Jersey
I just went to look at a 5 ton military dumptruck with my friend. Its a 1970 turbo'd 465 continetal multi fuel engine. Seemed to run good with lots of smoke ;Sweet . It was in good shape too. The guy wants 5000 for it which seems like a good deal compared to others ive seen. Is there anything I should know to tell my friend about if he buys it? This is pretty much a beefed up deuce and half right?
Chris
Ramprat
Inside your OODA
I've driven 5 ton trucks, but never a dump truck & have never worked on em at all. Always took em to the motorpool or had them come and get em when they broke LOL LOL LOL
Duke
PA
Chris
What kind is it? Kaiser? That's a great deal if it has a dump installed on it already. Where can you get so much iron for $5,000?? NOWHERE. If he plans on driving it OTR, just make sure it won't cost too much to get road-ready.
Buddy of mine has the same truck at a camp upstate and we 4 wheeled that thing places only a bulldozer could go.
chris88
Wayne, New Jersey
Hes not going to run it he just wants to get it as more of a toy then anything. Its an AM general. Its got a 5 speed spicer trans, does anyone know if its syncroed or not? The tires are still really good and the dump body works. The truck fired right up and idled fine. It smokes a lot but its black fuel smoke so its nothin to worry about. For 5 grand its a great truck I would think. If I had the money I would have bought it already. If my friend doesnt buy it the truck is most likely going to auction in atlantic city in april.
Chris
chris88
Wayne, New Jersey
Chris
chris88
Wayne, New Jersey
Am General I think it is. Hes not going to drive it OTR he just wants it as a toy. Its got a 5 speed spicer trans does any one know if thats syncroed or not? Its a good runnin truck and the dump body works fine. If he doesnt buy the the truck it will be going to atlantic city for auction in april.
Chris
Jarlaxle
Bregan D'aerthe
New England
Sounds good. The trans should be synchronized. Top speed will be ~55MPH, should be governed to 2400RPM. Tires are probably 9.00-20 tube type.
Shift pattern is odd--
R25
134
Duke
PA
Chris
I had a 5 speed spicer and it was synchroed. Not sure if it was the same one though. ES05D I think it was.
Freight_Train
Traitor to the brotherhood
Gadsden,Al
being a 5 ton the tires will be the BIG ones.they didn't use the 9.00x20s on anything larger than a Deuce.Think the 5tons used 11.00x20 and have the extra lugs so you can't just grab deuce wheels and tires like I do for $25 each.Also,a 5 ton GVW is well into Commercial Drivers License area unless you find a loop hole and register it with Zero load at which point you better not put anything into the bed.I personally would go for a Deuce and a half.14,000Lb Curb weight,5000Lb load rating(10,000Lb on road but DMV down here uses military "offroad" rating).Parts are easier to find and cheaper(the $25 tires mounted on rims with 90% tread for example)
nevrenufhp
torque ******
Sacramento
They'll be 11.00X20's like mentioned, and be a 10 lug big rig pattern. Also, you'll get ~6.72 gears(some were into the 7.'s). Sounds like the fuel screw was already done too. Surely worth the price...who bought it?
Nanohawk
