FoMoCo
I have installed 3 clutch masters on my 1994, The first 2 were from Napa and they looked just like the one that was on the truck when I bought it about 10 years ago (the black plastic ones). The first Napa one I bought as a kit which included the Master, new Line and Slave cylinder, so the line is newish. They all started leaking inside where the pushrod from the pedal goes. The one I have now I found at Clarks Discount Auto from Belltower, CA. This one is aluminum and bolts in with no mods, but the fluid reservoir is angled about 30 degrees toward the motor. This is not a problem.
My question is, does anybody have a cure for this problem? Is there a Master available from Wilwood that will work? and if so what is the part number?
Also the slave design is a joke, I would like to replace the master, slave and line at the same time.... Help.....
FYI, since I bought my 2005 VW TDI, I might put 200 miles a year on the Truck, so the Masters have little to no miles on them.
I have been using DOT brake fluid, maybe I can use a Hydraulic fluid instead?????
