35x12.50R16 heavy haul tire recommendations
Crumm
No Comment
Fairbanks, AK
I just picked up a camper and I am approaching the weight limit of my tires.
My current tires are 315/75R16 Coopers but they are only rated for 3,200@50. I found that Nitto makes a Mud Grappler 35x12.50R16's that are rated for 3,750@65 and Toyo makes a Open Country MT 315/75R16 that are rated at 3,860@65. I am sure you know but 315/75R16 is the same basic size as 35x12.50R16 so we are comparing apples to apples here. I believe geonc runs Nitto's? Anyone else? Any other 35" tires out there that have a higher rating?
Right now I am at about 4,700 on the front and 5,800 on the rear so I am OK(if you don't look at the GVW sticker)but once I add passengers and a bunch of gear I will be approaching the 6,400 limit on the rear tires. Doesn't take much to add 600 lbs of people, food, water and supplies. If I got the Toyo's I could haul 1,320 lbs more than I can on the Coopers, just think how much beer that would be :D
Any recommendations on tire choices?
p.s. Don't try and talk me into smaller tires. I like my big ones.
86 1 tonhauler
put 10 ply power kings on it and be done with it they pull hard and clean real well
hitechredneck
Hillbilly Deluxe
Clayton De
Super Swamper radial TSL are 10 ply load range Es and work great I have 36s and have well over 1 ton of gravel in my bed and very little sidewall give, pLus they look damn good and sound even better.
Crumm
No Comment
Fairbanks, AK
I went with 315/75R16 Toyo M/T's rated for 3,860@65. No way I will be over 7,720 on the rear axle.
Diezel_Cowboy
It's not like a real ***!
A little place called "nun a ya binez!"
Hey Crumm,
Is your truck stock height?? I like the looks of those 315's, I am running 285's right now but if i thought 315's would fit under stock i would run them. If you arent stock i'd like to hear whatcha had to do for clearance. Thanks!
Crumm
No Comment
Fairbanks, AK
Nope not stock. I have a Off Road Unlimited shackle reversal on the front which raises the front 2.5" I also have a add-a-leaf in the rear that picked it up about 1.5". In addition I had to shim the front bumper out about 1/2" for additional clearance when turning. With it setup like this my 315/75R16 coopers did not rub at all. The new 315/75R16 Toyo's do rub a little on the front leaf springs when turning tight. I believe the new rub is due to the big side lugs.
Alleycat
