Will 35 in tires fit under my stock height 89 f-250 4x4? A guy in town has a set of 4 aluminum rims with 4 new kuhmo tires for 400. Just wondering if it will fit.
They should fit in the rear no problem but I believe you will rub in the front. My 93 F350 is running 315-75/16 which work out to right around 34". I have very little clearance in front but don't rub. If I am flexing it offroad it can rub but hasn't done so much or badly.
That is a really good price however. If you want to run 35s' you will have to lift it a little IMO.
I am running 33's on mine and I think a set of 35's will rub some but you could trim the fenders and bumper where they rub. I dont think it would be too much triming at all.
Smoking deal for $400,.. just buyem and tryem, Like mudslinger said you can always get your money back, and them some. The tires alone are 5-700 for 35" tires.
That said, they should fit but you may need to trim the front bumper a little. Now may be a good time to for a front add-a-leaf.
