The frame rails are different right behind the front bumper. The 2wd frame is a "open c" type frame, the 4wd frame is closed in and has a dimple with a hole in it. This is to mount the front leaf spring shackle. You will have to modify the 2wd frame to accept and support the front leaf spring shackle, or buy or make a shackle reversal kit and put the shackle in the rear and mount the leaf springs to a crossmember behind the bumper.
You will also have to locate the holes for the rear mount. There is some debate on how many of any holes are there already, but most people end up drilling some holes for the rear mount on a 2wd frame.
