2wd Leveling?
crewchief219
Wichita, KS
So I've searched with no luck.. hate the raked stance of my 2wd obs and no time for a 4wd conversion yet, so want to see if anyone has used 2" coil spacers on a 2wd. Will camber be noticibly different? If so, what will it take to make it right?
DaveBen
Ukiah, Ca
Jacking up the front end will change the caster, but that can be corrected within limits. I have not seen springs for this purpose.
Dave
may want to look into a dream beam set up,
but the cost could be that of a D-60 install.
spacers up front will change caster like dave said, and it can be somewhat corrected.
the cheapest and easiest way to fix this, is to pull the rear blocks out of it :D
ealiaga12
