21 Inches Boost
oreana123
Boise, Idaho
I was pulling my boat up a hill yesterday and I reached 21" of boost. This is the highest boost I have seen on this truck. Mods are; Tymar intake, cat delete, exhaust valve removed. No chip but I do run Stanadyne additive. John S
Mike
Stroker
Cora
Re: 21" Boost
Originally posted by oreana123
Inches of a column of Mercury- vacuum. Pounds of what?
I hope that your turbo isnt pulling a vacuum on your intake manifold. That would be 21 PSI, pounds per square inch of air pressure.
Mike
geonc
SPIDER BAIT
NECKVILLE North Carolina
That's about right for what you have.........I can hit 24 psi when hooked to a 30k lb sled:D
Of course that will all change after a '99 HPOP......4 position chip.....and some SWAMPS:smoke::yell:
Bean
Not with those twins. But the new setup wil be much nicer. :)
morepower02
minnesota
keep us informed. Have any #'s yet? Mine sucked, Boost was low on the dyno. Found map line loose after I got home.:rolleyes:
thamojster
