Macrobb
Pretty sure all ABS systems work on pressure /after/ the master cylinder, not before it. As long as you put the hydroboost unit behind the stock master cylinder, I see no reason why it wouldn't work.-I'm not sure you'll want to/be able to put hydro on that. New vehicles have a much more robust braking system than the old ones and it may mess with the ABS as well. I've had issues in the past modifying brake systems (different master cylinders/adding disc brakes, etc). Just a head's up.
And just to point out - master cylinders are designed differently for drum and disk brakes. You can't(shouldn't) swap them; if you put in disks instead of drums somewhere, you need a matching master cylinder.
