2000 F350 Electrical Issues
rellerman
Missouri
Hey all! I have a 2000 F350 4 door that I'm having some electrical issues with. I noticed it when I first bought the truck. The switch panel on the drivers side will roll down the passenger side window and the driver side rear window. Sometimes it will randomly stop working after rolling one of the windows down, or after trying the drivers side window down (which doesn't work at the moment). When the switch stops working, the lights go out on it, and none of the switches work. It also stops the windshield wipers from working. Everything else on the truck functions as it should, A/C, head lights and tail lights. No issues with it running funny or anything like that. Any idea on what could be causing it?
DaveBen
Ukiah, Ca
That sounds like a grounding problem. Look at the grounds under the dash. The door grounds also.
Yup. Start with the grounds.
Maybe see if the power windows and wipers are on the same fuse Circuit.
Next maybe the switches.
Lastly the gem module.
olsen726
