I have an 00 f250 and it has a small oil leak at the back of the engine, im recovering from hernia surgery and havent had this truck long so i would like some ideas before i tear into it considering im still not 100%
Check the valley (or have someone else if you can't climb up there) and see if there's oil there. If so it is probably the turbo pedestal O-rings. It's very common on the 7.3L. Happened to me. If it's dry down there it could also be the rear main seal. Mine leaks a few drops. I just put a piece of cardboard on the garage floor and don't worry about it.
Also check ORB plugs in the high pressure oil rails. You can replace a couple of the o-rings on the HPOP, but there is one that is considered non-servicable. All of the above too.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
