1995 boost
Dieselpowerking
Lewiston, idaho
I have a 1995 f250 4x4 auto transmission the truck seems to run great I just put pryo boost and trans temp gauges in and I'm only seeing 8 psi not loaded with full throttle turbo is screaming but it seems kinda low for boost. It has 4in exhaust adrenaline hpop new ipr 6.0 trans cooler riffraff plenum boots and upgraded stainless clamps. Other then that it's all stock.
Garbage_Mechan
Garbage Mechanic
Central Cal Foothills
14 psi was normal for my 96 when it was stock. Had to be really pulling to get that. You likely have exhaust leaks pre turbo or boost leaks post turbo.
Lots of little things to check on a stockish new to me rig.....
Might be a little low, but honestly without tuning, you won't see much.
Check for up pipe leaks, and the intake y boots. They like to slide off when tightening.
720Diesel
