1993 E4OD flex plate/ crank shaft spacer
stevebates
alexandria va
My Flex plate has broke. It galled the mating surface of the thick spacer between the end of the crank and the torque converter. I am looking for a replacement part. Can file on mine but would prefer using a better one.
stevebates
alexandria va
I am confused (not unusual these days). If I counted correctly, I have ten bolts to hold my flex plate onto the crankshaft. All the flexplates that I am seeing listed for a 93 NA IDI have nine. The flexplate I got from Rock Auto has nine. Did I get the incorrect flexplate or did I miscount my bolts.
You must have miscounted your bolts. IDIs have nine while the PSDs have ten. There is ten holes in some of the IDI flywheels/flexplates. Some of the earlier 6.9s had a small dowel in the crankshaft in the circle of flywheel bolts.
frankenwrench
overkill is under rated!
Weatherford tx
Im not sure if the idi is different from the idit in that spacer aspect, but I has one for an idit laying around.
Va_Mike
Southeastern Virginia
I am pretty sure I have a flexplate and the spacer for the E4OD that I pulled from my parts truck. If I have the spacer its yours if you want it, just pay shipping.
77 F-250
New Hampshire
I also have one out of a 91 van. Just pay shipping.
frankenwrench
Weatherford tx
Just looked at mine. Not sure if its of any interest
chris142
SoCal
The idi is loosely based on the IHC 266,394,345 and 392. Those also have only 9 bolts with an empty spot
Vincent
