1986 Water Separator Electrical Diagram
RDieselKid84
Mississippi
Does someone have the diagram for the seprator. I need to find witch wire go's to the water light. There's three wires going to it and what they are for. And if I can wire up a new style single wire seprator. Like the 87's have. I have all the manual's but not the electrical ones.
Cubey
Van dweller
USA
This is for 1990 vans, maybe it's the same?
RDieselKid84
Mississippi
Thanks Cubey, but the 90 is a single wire hook up and the 83-86 used three wires and that is what I am looking for.
ifrythings
BC
Hope this helps, pretty sure the ground wire is the case being bolted to the firewall.
RDieselKid84
Mississippi
Does enbody know where the fuel water switch is located on the 87 F250, it is the relay for the water in fuel light with a single wire sensor.
RDieselKid84
Mississippi
I checked and the three wires are the same but at a different location. They are on the seprator of the 86 and the relay some other location for the 87 with a single wire water seprator. Thanks for the reply.
ifrythings
BC
The “relay” on the 87 is located on the engine beside the fuel filter and thermostat housing.
Diesel8873ne
Mass
Not sure if the 88 is the same but mine is a 88 and my relay was melted. Old picture but might help with finding it
RDieselKid84
Mississippi
Thanks, I found the one on my 89 right there also. I't was melted also. I guess I need a wiring harness and a relay to hook up my new water seprator and wire it in the circuit.Thanks for all the help I just didn't know where to look for this relay. Now I need a short harness and plug for the relay.
Alleycat
