Bigblocknick
I’m I need of some help. I have a 1986 Ford F-250 with an 7.3idi in it when running the truck on the front tank I can prime it at the shradder valve and will prime just fine, I will take the truck for a drive it will run ok then it will surge but stay running and when I come to a complete stop the truck will idle rough and shut off but can restart after cranking for 30plus seconds. This problem only happens on the front tank rear tank performs normally. I have recently replaced sending units in both tanks, new selector valve, new mechanical fuel pump and injector return lines. Fuel lines seem to have a good connections no signs of leaking to the naked eye. I have read in another form that a guy had put a electric fuel pump on his truck with a similar issue, would it be beneficial to this issue or is there still a underline problem that will continue.
