if you get a destroked adapter it comes with a pilot bushing so you can use your zf with a 12in dodge clutch... then get a 12in ford clutch and press plate
or you could do what i did, get a 13in 5speed dodge flywheel from southbend,( it has a bearing style pilot bearing machined it to fit the zf input shaft... then run a 94-97 13in southbend psd clutch
the destoked adapter is very nice... ive heard the ford-cummins one isnt plus you have to grind your trans... ive heard the destroked mounts suck, while i got ford-cummins mounts and they are awesome
so, having done this swap myself, id say destroked adapter, fordcummins.com motor mounts
