it just stops wiring from shorting out and catching fire. if the sensor on the master cylinder starts leaking. It''s an inline fuse that goes near the master cyl.
Ok thanks for the info............ Cruise control doesn't work, I don't suppose that will fix it either. Only thing on the truck that doesn't work and I have never really had time to dig into it and find out why it doesn't work.
Mines not even hooked up now since I did the hydroboost the f450 master cylinder didn't have that sensor. I do have the upgraded harness that they plug into your wiring and plug into the sensor. I got it off a parts truck that they must have taken in for the recall. I had it on my truck for a while. It looks like it just puts an inline fuse in the wiring. There is a sticky on here about the recall notice.
3'rd sticky from the top-read all about it....
2x remove the wires from the master cylinder until you get the recall done.
FWIW it took all of 3 minutes for the tech to install the inline fuse on my IDI F250. All done in their parking lot adjacent to the service counter.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
