junk
Ok got the engine in my 93 and got it fired up. I have a leak in the Up-pipe joint for the turbo. I checked the ATS instructions to see if I missed anything. In the ATS turbo install instructions it says to remove the passenger side exhaust studs and install bolts to hold the Y part of the up-pipe to the passenger side exhaust manifold. Did I screw up by not doing that? I still have studs in that exhaust manifold. I've remove two turbos and one had bolts and one had studs. My up pipe pieces don't seem to be seated together as deep as other up-pipes I've messed with. It seems like the bottom piece needs to go up 1/4" or more. Now the space between the OD of the bottom pipe and ID of the upper pipe is only like .030" or less is there a chance that will close up once I run it a little bit?
Now if I do need to remove those studs and put bolts in I'm assuming I'll end up breaking them off so I'm wondering if it might be easier to remove the passenger side exhaust manifold to straighten this out?
Thanks,
Jeremy
Thanks,
Jeremy
