093 turbo ww2 moose junior
FastestIdIinthe707
Santa Rosa California usa
Just installed a wicked wheel 2 and a moose junior pump on my truck and it runs great! Whistles like crazy! Still have a fuel leak I need to fix but very excited with the new parts!
cpdenton
Truck needs paint.
Conway AR
Nice!
I still remember those "mew Moose junior pump days". And BTW, 15000 miles later, it is still just as satisfying!
anotheridi
NE
Did you install the WW2 yourself? If so do you just mark the nut and retorque it to the same spot, or do they come with torque specs to use? I know the powerstroke guys seem to just install the wheel with no balancing and have great results with it, I was unsure if our install was the same or not.
FastestIdIinthe707
Yes I did install it myself. I just hit it a few time with an impact. Didn't wanna break the shaft so I just hit it a a couple times to make sure it was tight. Didn't come with a torque spec but might be one online.
dont worry. that project isnt going anywhere.
your truck is #1
i get my WW2 on sunday!!!
FastestIdIinthe707
Nice man!! It sounds great! Your gonna like it. I can't wait too see what boost I'm pushing. I got to get my pump timed still and get exhuast on my truck then I'll have good accurate numbers
did you get the updated up pipe castings?
these turbos are notorious for up pipe leaks.
is your DP a slip or a v-band clamp?
Russ (typ4) carries them for the OEM unit.
dont know what he can do for the aftermarket unit.
