03 ford excursion rear window leak
Oledirtypearl86
Whitehall MT
Hey guys so I've had this excursion for a few months now an put about 9k miles on it and love it but it's been raining a ton lately well as I was traveling to Utah and noticed my back window was leaking from the trim around the glass is there a drain that might be plugged
snicklas
6.0 and Loving It!!
Staff member
Greenfield, Indiana
I’ve not had a leak there. I would check the gasket around the opening. Look at where the glass mounts. I would also look and make sure it’s not something like the luggage rack or even the high mount brake light. I had a leak in my 11 F-150 and it was the high mount brake light allowing water to enter the cab through a crack in the lens.
Also make sure it’s not the rear washer. I had the hose come loose and it would leak on the passenger top whe. I would hit the washer......
lewisstevey7
