I think the lines run along the outside of the body along the passenger side frame rail, then up into the rear air box. Is it indeed a bad line, or bad o-rings in the the joints? Here is a link to an article on our sister site www.superdutydiesel.com. It is for an upgrade to insulate the lines to help with cooling. It has pictures of the route of the lines.
I have not worried about the upgrade, and mine will make it cold in the truck. Yesterday here it was 95 - 97 degrees, not too humid, just way early for those temps here. The kids asked me to turn up the heat while we were out driving in the heat.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
