02 Super Duty Key fob programing?
NJKen
is a daddy!
Central NJ
Topic says it all. Anyone know how to do it? I picked up a few from a slavage yard to replace my smashed one.
Ken
sagebel
Waverly, GA
Get in, shut the doors. Place key in ignition and the desired key fob in your other hand. cycle the key on and off(do not start it, just to were the wait to start is lit) After a few cycles of the key(5 if remember correctly, the door locks will start to lock and unlock as you cycle the key. While continuing to cycle the key, alternate depressing the lock and unlock buttons on the key fob. Press the buttons about 3 or 4 times and then stop. The key fob should work now. I think this procedure is in the owner's manual. Also, if you have more than one Ford, you can do this with both vehicles(both will work with the same fob) Hope this helps.
Scott
NJKen
is a daddy!
Central NJ
There must be something more to it than that. I am going to have to hunt for a procedure. I cant seem to locate my service DVD for some reason -cuss
Ken
lewisstevey7
