00 van rear axle , perfect for disk swap
Double-S-Diesel
parts seller
derry pa
355 gears, not shure if LS will have to look again 8x6.5 bolt pattern e brake inside the rotors, will need new rotors, pads
same width +- 1" from an obs, spring perches will need mover, and shock mounts fabbed , other wise just abot a direct swap for an obs, was gonna put it on mine, but dont have any obs trucks now
$250 offer
6 Nebraska IDIs
I thought the year change was 00. I think even today they still use the 8x6.5 bolt patter wheels too.
tech51
San Antonio, TX
The only 10.25 disc brake rear end from Sterling was on the 97-00/01 F250 HD. And it was a 7 bolt lug set-up.
tech51
San Antonio, TX
The 70 ring gear is almost the same size as a 10.25. I would stay away (if you pull/mud a lot) from the D60
subway
be nice to the admin :D
York PA
Not a bad deal, I wish I saw this before I rebuilt my axle last year.
FarmerFrank
Blairsville, Pa
Derry Pa?? Didn't know of another member that close to me!
The perches from a 98 van had to be moved in 1" each side to go into my 94 F350
Cv axle
