So, when I I was getting off the interstate heading home with it, I decided to push the needle a little too far. Gauge said I still had 20 to empty....when I took the sharp turn and hard braking at exit 125, she stalled out. Took some cranking before it would start back too... oops.
Good thing it wasn't a 6.0. That little oops can cost you a set of injectors. To the point, on the later 6.0's Ford put in the PCM, if you get extremely low on fuel, the PCM will cause the truck to run rough, to get you attention and get you to look at the gauges.
Congratulations on the new truck. I hope you enjoy it for years to come. As much as I like the IDI era trucks, the Super Duty Excursion is really nice for road trips.......
