Dash lights
94turbocrewcab-lb
Mid coast Maine
So I’ve had some issues with my light switch burning up once in the past. And I changed it out..but recently I was driving at night and lost my dash lights. The high beams also went out and when I went to low beams and back to high it worked again.
Not sure what’s up but I’m guessing it’s the switch again?
Is this all cured with the relay mod for the headlights?
Thanks
Andrew
The connector for the headlight switch has all the juice running through it, as they age they get corroded and get hot and screw all sorts of things up. I am willing to bet the relay mod will fix it.
KansasIDI
Hopelessly addicted to IDIs
Wilsey, KS
New switch and relay mod fixed my service truck, I ran into other complications due to the daytime running lights
Greenie
A trailer with non LED running lights will shorten the life of a headlight switch and connecting wires too.
