OK there is a wicky or whatever you call it in the tech section I did some time ago on the intermittent box.
That being said, there is also a small plastic cover on the gear box of the wiper motor. carefully lift it off and look under there, the contacts for the park are under that and work off that. I had a similar problem that I thought was the intermittent box so I documented that repair.
Turns out that once I pulled the cover of the wiper motor gear box, that there is a disc attached to the main gear that rotates and makes contact with old point type ign contacts on the plastic cover. My disc fell off the gear completely it was so worn out. I replace the whole wiper motor and it has worked flawlessly since....
Just sayin it's likely the contacts in the gear box that recognize the park location is all
JM2CW
