Started Intercooler install lots of pics
alienturtle
Human
Ripon, CA
Finally started my intercooler install today and got fairly far on it. Iv had this intercooler sitting in my room for a while just haven't had the time to get it installed. Here are a bunch of pics of the install. I should be finishing it up tomorrow and get more pics uploaded. I have the cooler mounted and all the tubing laid out in my head where i want to go with it. But because my tubing is 3" aluminum tubing i have to use a cut off disk that hasnt been used on steel yet due to welding purposes. Of course the moment i realize this all my local stores where closed -cuss. Enjoy ;p take a look.
Top mounting brackets.
Bottom mounting brackets.
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
What intercooler is that? What are you planning to do for grille fitment afterwards, or does the stock grille fit in over the IC?
Looks good!! ;Sweet
typ4
Newberg,OR
looks to me like the wrx IC off ebay, I have almost the exact one on my sandrail, the grill will need to be sliced off the back. to fit
alienturtle
Human
Ripon, CA
I currently have the billet grill so the intercooler clears no problem.
Yes this is a cooler from ebay
Bar & Plate Intercooler
Core Size: 24x12x3 inch
Overall Size: 31x12x3 inch
Inlet and outlet sizes: 3 inch
more pics to come this afternoon!! ;Sweet
88beast
pa
damn he put that cummins in now hes got that dodge hitch cover too soon hell have dodge rims and dodge axles and other crap
but looks good man
88beast
pa
really please dont do them like oreo on fte do them right and move them foward to the door edge
alienturtle
Human
Ripon, CA
More pics.. still not done with it because i had to order a speciel 90 with 2" on one side and 3" on the other. but all the pipes got tig welded together yesterday. So as soon as i get that elbow in its a matter of putting it back together. My on board air pump made the cold side very fun.
Got the support cut out to accept the pipe
Cold side. Actually has plenty of room for engine shake.
Tig welder at work :)
hesutton
The Anti-Anderson
Bowling Green, KY
Looking good AT. Hope to see it finished soon. Did you ever get your wiring sorted out? I'm still grinding away at it when I get time off from work (rare these days).-cuss
Heath
alienturtle
Human
Ripon, CA
Heath
i got the box mounted but nothing hooked up yet. iv been working on the intercooler the last couple days. I did finally get my turn signal, 4x4, low range, rear anto lock lights wired in finally for the dash.
what a fun mess..cant wait to get the dash pulled out and all this junk wrapped up in a harness.
bike-maker
albany, OR
Where did you get the holders for the dash indicator bulbs? I'm looking for some like yours that don't use the stock circuit paper.
Bradz
